asp中如何在客户端把查询的结果集在本机上保存为excel
2015年10月27日 12:48 本文热度 9968
http://www.haolizi.net/example/view_4000.html
保存的代码:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
Class   ExcelGen
Private   objSpreadsheet
Private   iColOffset
Private   iRowOffset
Sub   Class_Initialize()
Set   objSpreadsheet   =   Server.CreateObject( "OWC.Spreadsheet "
''Set   objSpreadsheet   =   Server.CreateObject( "Excel.Application ")
iRowOffset   =   2
iColOffset   =   2
End   Sub
Sub   Class_Terminate()
Set   objSpreadsheet   =   Nothing   ''Clean   up
End   Sub
Public   Property   Let   ColumnOffset(iColOff)
If   iColOff   >   0   then
iColOffset   =   iColOff
Else
iColOffset   =   2
End   If
End   Property
Public   Property   Let   RowOffset(iRowOff)
If   iRowOff>   0   then
iRowOffset   =   iRowOff
Else
iRowOffset   =   2
End   If
End   Property
Sub   GenerateWorksheet(objRS)
''Populates   the   Excel   worksheet   based   on   a   Recordset ''s   contents
''Start   by   displaying   the   titles
If   objRS.EOF   then   Exit   Sub
Dim   objField,   iCol,   iRow
iCol   =   iColOffset
iRow   =   iRowOffset
For   Each   objField   in   objRS.Fields
objSpreadsheet.Cells(iRow,   iCol).Value   =   objField.Name
objSpreadsheet.Columns(iCol).AutoFitColumns
''设置Excel表里的字体
objSpreadsheet.Cells(iRow,   iCol).Font.Bold   =   True
objSpreadsheet.Cells(iRow,   iCol).Font.Italic   =   False
objSpreadsheet.Cells(iRow,   iCol).Font.Size   =   10
objSpreadsheet.Cells(iRow,   iCol).Halignment   =   2   ''居中
iCol   =   iCol     1
Next   ''objField
''Display   all   of   the   data
Do   While   Not   objRS.EOF
iRow   =   iRow     1
iCol   =   iColOffset
''For   Each   objField   in   objRS.Fields
''If   IsNull(objField.Value)   then
''objSpreadsheet.Cells(iRow,   iCol).Value   =   " "
''Else
''objSpreadsheet.Cells(iRow,   iCol).Value   =   objField.Value
''objSpreadsheet.Columns(iCol).AutoFitColumns
''objSpreadsheet.Cells(iRow,   iCol).Font.Bold   =   False
''objSpreadsheet.Cells(iRow,   iCol).Font.Italic   =   False
''objSpreadsheet.Cells(iRow,   iCol).Font.Size   =   10
''End   If
''iCol   =   iCol     1
''Next   ''objField
For   i=0   to   objrs.fields.count-1
If   IsNull(objrs.fields(i).value)   then
Elseif   i=3   then
objSpreadsheet.Cells(iRow,   iCol).Value   =   cstr(objrs.fields(i).value& " '' "
else
objSpreadsheet.Cells(iRow,   iCol).Value   =   objrs.fields(i).value
End   If
iCol   =   iCol     1
Next   ''objField
objRS.MoveNext
Loop
End   Sub
Function   SaveWorksheet(strFileName)
''Save   the   worksheet   to   a   specified   filename
On   Error   Resume   Next
Call   objSpreadsheet.ActiveSheet.Export(strFileName,   0)
SaveWorksheet   =   (Err.Number   =   0)
End   Function
End   Class
Dim   objRS
Set   objRS   =   Server.CreateObject( "ADODB.Recordset "
      Set   con=Server.Createobject( "ADODB.Connection ")
con.open   "provider=microsoft.jet.oledb.4.0;data   source= "&   server.MapPath( ". "& "/database/project.mdb "
objRS.Open   session( "sql "),   con,1,1
Dim   SaveName
SaveName   =   Request.Cookies( "savename ")( "name "
Dim   objExcel
Dim   ExcelPath
ExcelPath   =   "Excel\ "   &   SaveName   &   ".xls "
Set   objExcel   =   New   ExcelGen
objExcel.RowOffset   =   1
objExcel.ColumnOffset   =   1
objExcel.GenerateWorksheet(objRS)
If   objExcel.SaveWorksheet( "c:/test.xls ")   then   %>
<script   language= "javascript "
window.alert( "数据已经保存在C盘下test.xls文件里,请核实. ");
history.back();
</script>
Else
Response.Write( " <script   language=javascript> window.alert(数据保存失败。); </script> "
End   If
Set   objExcel   =   Nothing
objRS.Close
Set   objRS   =   Nothing
''session( "sql ")= " "
session( "Sql ")保存的是查询的sql语句
运行完后test.xls就保存在了服务器上了。但是我想保存在客户端上(在客户端上运行完后保存在了服务器上   服务器是运行iis这台机子)
客户端:
查询页面:   <input   type=button   value= "导出 "   onClick= "javascript:export_onclick(); "
  function   export_onclick()
window.location.href   =   "rp_export.asp?reports_sql= " sql;//这里的sql可以用你的session( "Sql "
rp_export.asp:
<%@   Language=VBScript%>
<html>
<head>
<meta   http-equiv= "Content-Type "   content= "text/html;   charset=gb2312 "
<title> 无标题文档 </title>
</head>
<body>
Response.Clear
Response.ContentType   =   "text/xls "
Response.AddHeader   "content-disposition ",   "attachment;   filename=export.xls "
''点导出按钮后事件
set   conn=server.createobject( "adodb.connection "
conn.open   "sql   server驱动 "
SQL=session( "Sql "
''Set   rs=Server.CreateObject( "Adodb.RecordSet ")
Set   rs=conn.execute(SQL)
total=rs.fields.count
while   not   rs.eof
i=0
while   i <cint(total)
      Data=Data&rs(i)&chr(9)
i=i 1
wend
Response.Write   Data&chr(13)
Data= " "
rs.moveNext
wend
rs.close
conn.close
Response.Flush
Response.End
</body>
</html>
该文章在 2015/10/27 12:48:06 编辑过
