VB的Listview保存读取
2013年12月14日 22:6 本文热度 9669
完整代码
注:Listview定义了4个列,自己需要几列改下就好
Option Explicit
'读写INI文件
Private Declare Function GetPrivateProfileString Lib "kernel32" Alias "GetPrivateProfileStringA" (ByVal lpApplicationName As String, ByVal lpKeyName As Any, ByVal lpDefault As String, ByVal lpReturnedString As String, ByVal nSize As Long, ByVal lpFileName As String) As Long
Private Declare Function WritePrivateProfileString Lib "kernel32" Alias "WritePrivateProfileStringA" (ByVal lpApplicationName As String, ByVal lpKeyName As Any, ByVal lpString As Any, ByVal lpFileName As String) As Long
Private Sub Form_Load()
Randomize
End Sub
Private Sub 随机值_Click()
Dim i As Integer, j As Integer, lv As ListItem
ListView1.ListItems.Clear
For i = 0 To 14
Set lv = ListView1.ListItems.Add(, , i + 1)
For j = 0 To 2
lv.ListSubItems.Add , , CInt(Rnd * 30)
Next j
Next i
End Sub
Private Sub 保存_Click()
Dim si As Integer, sj As Integer, tmpstr As String
If ListView1.ListItems.Count = 0 Then MsgBox "没有可保存的内容", vbInformation, "提示": Exit Sub
tmpstr = ListView1.ListItems.Count
WritePrivateProfileString "统计项", "总行数", tmpstr, App.Path & "\ABC.ini"
tmpstr = ListView1.ListItems(1).ListSubItems.Count
WritePrivateProfileString "统计项", "总列数", tmpstr, App.Path & "\ABC.ini"
With ListView1.ListItems
For si = 1 To .Count
WritePrivateProfileString "第" & si & "行", "第1列", .Item(si).Text, App.Path & "\ABC.ini"
For sj = 1 To .Item(si).ListSubItems.Count
WritePrivateProfileString "第" & si & "行", "第" & sj + 1 & "列", .Item(si).SubItems(sj), App.Path & "\ABC.ini"
Next sj
Next si
End With
MsgBox "保存成功!", vbInformation, "提示"
End Sub
Private Sub 读取_Click()
Dim sr As Integer, sc As Integer, li As Integer, lj As Integer, tmptxt As String, lvs As ListItem
tmptxt = Space$(100)
GetPrivateProfileString "统计项", "总行数", "0", tmptxt, 100, App.Path & "\ABC.ini"
sr = CInt(tmptxt) '总行数
sc = CInt(tmptxt)
If sr = 0 Then
MsgBox "总行数为零哦"
Exit Sub
Else
End If
For li = 1 To sr
For lj = 1 To sc '这里你的列表
GetPrivateProfileString "第" & li & "行", "第" & lj & "列", "", tmptxt, 100, App.Path & "\ABC.ini"
If lj = 1 Then
Set lvs = ListView1.ListItems.Add(, , tmptxt)
Else
lvs.ListSubItems.Add , , tmptxt
End If
Next lj
Next li
End Sub
该文章在 2013/12/14 22:06:18 编辑过
