群晖NAS机设置任务计划通过API更新Cloudflare DDNS动态IP域名解析,完成动态IP的域名解析,适用于有不固定动态公网IP的情况。
本文将整体过程拆分为三个部分:
1、获取 Cloudflare API Token
2、获取 Zone ID / Record ID
3、编写 DDNS 脚本并设置定时运行
下面是详细操作步骤:
点击右上角头像:
要先做身份验证,否则后面无法保存,会提示未做Email验证:
完成双因素身份验证后,点击“API令牌”-》“创建令牌”:
这里因为只需要动态更新IP到DNS,所以只点击“编辑区域DNS”-》“使用模板”:
按照下面设置:
点击“继续以显示摘要”:
点击“创建令牌”:
至此就完成Token的创建,务必记住上面创建的令牌,复制token并保存起来(注意这个Token只会展示这一次,忘记了就只能重新创建一个Token)。
为域名新增一条 A 记录,例如主域名为 abc.com,可新建 ddns.abc.com,IP 可随意填写,在浏览器中输入以下地址打开,其中,<ZONE_ID> 替换为上面拿到的域名对应区域ID(ZONE_ID),其余内容不要更改:
https://dash.cloudflare.com/api/v4/zones/<ZONE_ID>/dns_records?per_page=200&order=name&direction=asc
{"result":[{"id":"adb5019e5d96ff4b213a80983a6637bc","name":"ddns.abc.com","type":"A","content":"121.40.20.16","proxiable":true,"proxied":false,"ttl":1,"settings":{},"meta":{},"comment":null,"tags":[],"created_on":"2026-06-05T04:34:11.864432Z","modified_on":"2026-06-05T04:34:11.864432Z"},{"id":"fab2fdfbc16549594e52c6294adf691d","name":"*.abc.com","type":"A","content":"27.45.25.1","proxiable":true,"proxied":false,"ttl":1,"settings":{},"meta":{},"comment":null,"tags":[],"created_on":"2026-06-05T04:32:21.100399Z","modified_on":"2026-06-05T04:32:32.120333Z"},{"id":"82b174a7adc2a476df7d2207702a0e17","name":"abc.com","type":"A","content":"27.45.25.1","proxiable":true,"proxied":false,"ttl":1,"settings":{},"meta":{},"comment":null,"tags":[],"created_on":"2026-06-05T04:32:21.083773Z","modified_on":"2026-06-05T04:32:33.205554Z"},{"id":"f930ccb856e6b56b6c3a2b2943162f43","name":"www.abc.com","type":"A","content":"27.45.25.1","proxiable":true,"proxied":false,"ttl":1,"settings":{},"meta":{},"comment":null,"tags":[],"created_on":"2026-06-05T04:32:21.112018Z","modified_on":"2026-06-05T04:32:33.955677Z"}],"success":true,"errors":[],"messages":[],"result_info":{"page":1,"per_page":200,"count":14,"total_count":14,"total_pages":1}}
上面黄色位置 id 就是域名 ddns.abc.com(二级子域名) 对应的“Record ID”:adb5019e5d96ff4b213a80983a6637bc(以实际看到为准)。
下面是此JSON格式化后的效果,会更直观些:
"result": [
"id": "adb5019e5d96ff4b213a80983a6637bc",
"name": "ddns.abc.com",
"type": "A",
"content": "121.40.20.16",
"proxiable": true,
"proxied": false,
"ttl": 1,
"settings": {
"meta": {
"comment": null,
"tags": [
"created_on": "2026-06-05T04:34:11.864432Z",
"modified_on": "2026-06-05T04:34:11.864432Z"
"id": "fab2fdfbc16549594e52c6294adf691d",
"name": "*.abc.com",
"type": "A",
"content": "27.45.25.1",
"proxiable": true,
"proxied": false,
"ttl": 1,
"settings": {
"meta": {
"comment": null,
"tags": [
"created_on": "2026-06-05T04:32:21.100399Z",
"modified_on": "2026-06-05T04:32:32.120333Z"
"id": "82b174a7adc2a476df7d2207702a0e17",
"name": "abc.com",
"type": "A",
"proxiable": true,
"proxied": false,
"ttl": 1,
"settings": {
"meta": {
"comment": null,
"tags": [
"created_on": "2026-06-05T04:32:21.083773Z",
"modified_on": "2026-06-05T04:32:33.205554Z"
"id": "f930ccb856e6b56b6c3a2b2943162f43",
"name": "www.abc.com",
"type": "A",
"proxiable": true,
"proxied": false,
"ttl": 1,
"settings": {
"meta": {
"comment": null,
"tags": [
"created_on": "2026-06-05T04:32:21.112018Z",
"modified_on": "2026-06-05T04:32:33.955677Z"
"success": true,
"errors": [
"messages": [
"result_info": {
"page": 1,
"per_page": 200,
"count": 14,
"total_count": 14,
"total_pages": 1
3、编写 DDNS 脚本并设置定时运行
通过上面的操作,已经获取到了所有必须的信息,下面就开始设置需要在群晖NAS机任务计划中执行的脚本:
#!/bin/bash
API_TOKEN="YOUR_API_TOKEN"
ZONE_ID="YOUR_ZONE_ID"
RECORD_ID="YOUR_RECORD_ID"
RECORD_NAME="ddns.abc.com"
CURRENT_IP=$(curl -s http://ipv4.icanhazip.com)
# 更新DNS记录
curl -s -X PUT "https://api.cloudflare.com/client/v4/zones/$ZONE_ID/dns_records/$RECORD_ID" \
-H "Authorization: Bearer $API_TOKEN" \
-H "Content-Type: application/json" \
--data "{\"type\":\"A\",\"name\":\"$RECORD_NAME\",\"content\":\"$CURRENT_IP\",\"ttl\":120}"
将上面的:
改为上面实际获取到的真实参数,其余内容不需要更改,然后保存执行,等待数分钟即可在日志目录看到更新记录,表示 DDNS 已成功运行。
该文章在 2026/8/28 11:24:27 编辑过
