C# 两种方案实现调用 DeepSeek API
2026年2月9日 14:14 本文热度 4574
本文提供了两种形式的调用方法:
1、原生官网 API 地址调用。
2、通过腾讯云知识引擎原子调用。(适合原生调用繁忙和失败的备用场景)
开发运行环境
操作系统: Windows Server 2019 DataCenter
.net版本: .netFramework4.7.2
开发工具:VS2019  C#
访问API的一个通用方法
创建WebService类,该类的GetResponseResult 方法持续更新,主要根据 DeepSeek 对话补全的API文档,增加了HttpWebRequest.Accept 支持,同时增加了 GET 访问请求的 WebRequest.Headrs 的支持。
更新后的代码如下:
    public sealed class WebService
        public string ErrorMessage = "";
        private static bool validSecurity(object sender, X509Certificate certificate, X509Chain chain, SslPolicyErrors sslPolicyErrors)
            return true;
        public string GetResponseResult(string url, System.Text.Encoding encoding, string method, string postData,string[] headers,string ContentType= "application/x-www-form-urlencoded",bool secValid=true)
            method = method.ToUpper();
            if (secValid == false)
                ServicePointManager.ServerCertificateValidationCallback = validSecurity;
            System.Net.ServicePointManager.SecurityProtocol = System.Net.SecurityProtocolType.Tls | System.Net.SecurityProtocolType.Tls11 | System.Net.SecurityProtocolType.Tls12;
            if (method == "GET")
                try
                    WebRequest request2 = WebRequest.Create(@url);
                    request2.Method = method;
                    WebResponse response2 = request2.GetResponse();
                    if (headers != null)
                        for (int i = 0; i < headers.GetLength(0); i++)
                            if (headers[i].Split(':').Length < 2)
                                continue;
                            if (headers[i].Split(':').Length > 1)
                                if (headers[i].Split(':')[0] == "Content-Type")
                                    request2.ContentType = headers[i].Split(':')[1];
                                    continue;
                            request2.Headers.Add(headers[i]);
                    Stream stream = response2.GetResponseStream();
                    StreamReader reader = new StreamReader(stream, encoding);
                    string content2 = reader.ReadToEnd();
                    return content2;
                catch (Exception ex)
                    ErrorMessage = ex.Message;
                    return "";
            if (method == "POST")
                Stream outstream = null;
                Stream instream = null;
                StreamReader sr = null;
                HttpWebResponse response = null;
                HttpWebRequest request = null;
                byte[] data = encoding.GetBytes(postData);
                // 准备请求...
                try
                    // 设置参数
                    request = WebRequest.Create(url) as HttpWebRequest;
                    CookieContainer cookieContainer = new CookieContainer();
                    request.CookieContainer = cookieContainer;
                    request.AllowAutoRedirect = true;
                    request.Method = method;
                    request.Timeout = 1000000;
                    request.ContentType = ContentType;
                                continue;
                                if (headers[i].Split(':')[0] == "Host")
                                    request.Host = headers[i].Split(':')[1];
                                    continue;
                                else if (headers[i].Split(':')[0] == "Content-Type")
                                    request.ContentType = headers[i].Split(':')[1];
                                    continue;
                                else if (headers[i].Split(':')[0] == "Connection")
                                    request.KeepAlive = headers[i].Split(':')[1] == "close" ? false : true;
                                    continue;
                                else if (headers[i].Split(':')[0] == "Accept")
                                    request.Accept = headers[i].Split(':')[1];
                                    continue;
                            request.Headers.Add(headers[i]);
                    request.ContentLength = data.Length;
                    outstream = request.GetRequestStream();
                    outstream.Write(data, 0, data.Length);
                    outstream.Close();
                    //发送请求并获取相应回应数据
                    response = request.GetResponse() as HttpWebResponse;
                    //直到request.GetResponse()程序才开始向目标网页发送Post请求
                    instream = response.GetResponseStream();
                    sr = new StreamReader(instream, encoding);
                    //返回结果网页(html)代码
                    string content = sr.ReadToEnd();
                    sr.Close();
                    sr.Dispose();
                    return content;
                    return "";
            ErrorMessage = "不正确的方法类型。(目前仅支持GET/POST)";
            return "";
        }//get response result
}//class
原生官网实现
申请 API key
访问官网 DeepSeek,如下:
如图使用您的手机号注册一个帐户,然后再点击右上角 “API 开放平台” 链接申请 API key。
点击如下图:
访问左侧 API keys 功能菜单,点击 “创建 API key” 按钮,按提示输入名称等点击确认即可生成 key 值,请务必妥善存储,这是调用 API 的关键认证信息值。
调用实现
创建 DeepSeek 类,类说明如下表:
序号成员名称成员类型类型说明
1ApiUrl属性string访问的API路径
2ApiKey属性string申请的 API key 值
3Model属性string使用的模型名称
4ErrorMessage属性string反馈的异常信息
5ResultJson属性string得到的JSON结果信息
6chat(string say)方法void
调用原生对话API,参数为问题内容,
方法会写入 ErrorMessage和ResultJson属性值
7TC_chat(string say)方法void
调用腾讯云封装对话API,参数为问题内容,
类实现代码如下:
public class DeepSeek
        public string ApiUrl { get; set; }
        public string ApiKey { get; set; }
        public string Model { get; set; }
        public string ResultJson = "";
        public DeepSeek(string apikey = "")
            ApiKey = apikey;
        public void chat(string say)
            ApiUrl = "https://api.deepseek.com/chat/completions";
            Model = "deepseek-chat";
            WebService ws = new WebService();
            string[] headers = new string[3];
            headers[0] = "Content-Type:application/json";
            headers[1] = "Accept:application/json";
            headers[2] = "Authorization:Bearer " + ApiKey + "";
            var ReadyData = new
                model = Model,
                messages = new[]{
                    new {role="user",content=say}
            string postData = Newtonsoft.Json.JsonConvert.SerializeObject(ReadyData);
            ErrorMessage = "";
            ResultJson = "";
            string rs = ws.GetResponseResult(ApiUrl, Encoding.UTF8, "POST", postData, headers);
            ErrorMessage = ws.ErrorMessage;
            ResultJson = rs;
        public void TC_chat(string say)
            ApiUrl = "https://api.lkeap.cloud.tencent.com/v1/chat/completions";
            Model = "deepseek-r1";
            var ReadyData = new
                model = Model,
                messages = new[]{
            ErrorMessage = "";
            ResultJson = "";
            ResultJson = rs;
调用示例
示例代码如下:
string ak = "";  //您申请的 API key
DeepSeek dp = new DeepSeek(ak);
dp.chat("你好!");
string debug = string.Format("ErrorMessage:{0}\r\nResultJson:{1}", dp.ErrorMessage, dp.ResultJson);
腾讯云知识引擎原子调用
申请 API key
访问产品官网 https://console.cloud.tencent.com/lkeap,登录成功如下:
如图选择左侧“立即接入”菜单功能,选择 使用 OpenAI SDK方式接入,点击“创建 API KEY”按钮,按提示操作即可创建,创建成功如下图:
如图选择“APK KEY 管理”,即可查看已经成功创建的 KEY 列表,点击“查看”链接可以复制键值,如下图中操作步骤。
调用示例
在原生实现章节中已经实现了方法调用编写,这里仅展示调用示例,代码如下:
dp.TC_chat("你好!");
调用方法的区别在于调用了 TC_chat 方法,其它无需改变代码。
小结
更多详情请访问以下链接:
DeepSeek 官网:https://www.deepseek.com/
DeepSeek API 官网文档:https://api-docs.deepseek.com/zh-cn/
腾讯云 API 调试及文档查看:https://console.cloud.tencent.com/api/explorer?Product=lkeap&Version=2024-05-22&Action=ChatCompletions
感谢您的阅读,希望本文能够对您有所帮助。
转自https://blog.csdn.net/michaelline/article/details/145551627
该文章在 2026/2/9 14:14:43 编辑过
