C#彻底关闭Windows系统代码,不用shutdown命令
2025年5月14日 1:5 本文热度 4434
​以下是使用C#调用Windows API实现彻底关闭Windows系统的代码方案(不依赖 shutdown 命令):
方案一:直接调用 ExitWindowsEx  API(需管理员权限)
using System;
using System.Runtime.InteropServices;
public class SystemShutdown
    // 导入Windows API函数
    [DllImport("user32.dll", SetLastError = true)]
    private static extern bool ExitWindowsEx(uint uFlags, uint dwReason);
    // 常量定义
    private const uint EWX_SHUTDOWN = 0x00000001; // 常规关机
    private const uint EWX_POWEROFF = 0x00000008; // 关闭电源(若支持)
    private const uint EWX_FORCE = 0x00000004; // 强制终止进程
    public static void Shutdown()
        // 组合标志:强制关机并关闭电源
        uint flags = EWX_SHUTDOWN | EWX_POWEROFF | EWX_FORCE;
        bool success = ExitWindowsEx(flags, 0);
        if (!success)
            int errorCode = Marshal.GetLastWin32Error();
            throw new System.ComponentModel.Win32Exception(errorCode, "关机失败");
方案二:通过调整权限后调用API(更安全)
若上述方案因权限问题失败,需先获取系统权限:
using System;
public class AdvancedShutdown
    [StructLayout(LayoutKind.Sequential, Pack = 1)]
    private struct TokPriv1Luid
        public int Count;
        public long Luid;
        public int Attr;
    // 导入权限相关API
    [DllImport("advapi32.dll", SetLastError = true)]
    private static extern bool OpenProcessToken(IntPtr h, int acc, ref IntPtr phtok);
    private static extern bool LookupPrivilegeValueA(string host, string name, ref long pluid);
    private static extern bool AdjustTokenPrivileges(IntPtr htok, bool disall, ref TokPriv1Luid newst, int len, IntPtr prev, IntPtr relen);
    private static extern bool ExitWindowsEx(int flg, int rea);
    // 权限常量
    private const int SE_PRIVILEGE_ENABLED = 0x00000002;
    private const int TOKEN_QUERY = 0x00000008;
    private const int TOKEN_ADJUST_PRIVILEGES = 0x00000020;
    private const string SE_SHUTDOWN_NAME = "SeShutdownPrivilege";
    public static void ForceShutdown()
        IntPtr hToken = IntPtr.Zero;
        TokPriv1Luid tp = new TokPriv1Luid { Count = 1, Attr = SE_PRIVILEGE_ENABLED };
        // 获取当前进程令牌并调整权限
        OpenProcessToken(GetCurrentProcess(), TOKEN_ADJUST_PRIVILEGES | TOKEN_QUERY, ref hToken);
        LookupPrivilegeValueA(null, SE_SHUTDOWN_NAME, ref tp.Luid);
        AdjustTokenPrivileges(hToken, false, ref tp, 0, IntPtr.Zero, IntPtr.Zero);
        // 执行强制关机(组合多个标志)
        ExitWindowsEx(EWX_SHUTDOWN | EWX_FORCE | EWX_POWEROFF, 0);
    [DllImport("kernel32.dll")]
    private static extern IntPtr GetCurrentProcess();
关键说明
权限要求
必须以管理员身份运行程序,可通过以下任一方式实现:
在项目中添加 app.manifest 文件,设置:
<requestedExecutionLevel level="requireAdministrator" uiAccess="false" />
运行时检查权限并提示用户(示例代码见1)。
参数选择
 EWX_FORCE :强制终止未响应程序,但可能导致数据丢失。
 EWX_POWEROFF :物理关闭电源(需硬件支持)8。
若需重启,可改用 EWX_REBOOT 标志822。
错误处理
通过 Marshal.GetLastWin32Error() 获取错误代码1。
常见错误: ERROR_SHUTDOWN_IN_PROGRESS (5)表示已有关机任务。
测试调用
class Program
    static void Main()
        try
            AdvancedShutdown.ForceShutdown();
            Console.WriteLine("关机指令已发送");
        catch (Exception ex)
            Console.WriteLine($"错误:{ex.Message}");
注意事项
数据安全:强制关机可能导致未保存数据丢失,建议关键应用先触发保存逻辑。
系统兼容性:代码适用于Windows系统,不同版本需测试API行为差异。
替代方案:若需延迟关机,仍建议使用 shutdown.exe 命令(但用户要求禁用)。
该文章在 2025/5/14 8:54:39 编辑过
