SQLServer如何监控阻塞会话
2024年5月28日 10:28 本文热度 4934
一、查询阻塞和被阻塞的会话
SELECT
    r.session_id AS [Blocked Session ID],
    r.blocking_session_id AS [Blocking Session ID],
    r.wait_type,
    r.wait_time,
    r.wait_resource,
    s1.program_name AS [Blocked Program Name],
    s1.login_name AS [Blocked Login],
    s2.program_name AS [Blocking Program Name],
    s2.login_name AS [Blocking Login],
    r.text AS [SQL Text]
FROM sys.dm_exec_requests AS r
LEFT JOIN sys.dm_exec_sessions AS s1 ON r.session_id = s1.session_id
LEFT JOIN sys.dm_exec_sessions AS s2 ON r.blocking_session_id = s2.session_id
CROSS APPLY sys.dm_exec_sql_text(r.sql_handle) AS r
WHERE r.blocking_session_id <> 0
二、找出阻塞的具体SQL
SELECT
    r.session_id,
    r.blocking_session_id,
    t.text AS [SQL Text],
    r.wait_type,
    r.wait_time,
    r.wait_resource
CROSS APPLY sys.dm_exec_sql_text(r.sql_handle) AS t
WHERE r.blocking_session_id <> 0;
三、编写C#程序,每隔10秒监控SQL Server数据库中的阻塞会话,定位出阻塞的根源会话并终止它们,同时记录日志。
using System;
using System.Data.SqlClient;
using System.IO;
using System.Timers;
class Program
    private static Timer timer;
    private static string connectionString = "your_connection_string_here";
        timer = new Timer(10000); // 每10秒执行一次
        timer.Elapsed += CheckForBlockingSessions;
        timer.AutoReset = true;
        timer.Enabled = true;
        Console.WriteLine("Press [Enter] to exit the program.");
        Console.ReadLine();
    private static void CheckForBlockingSessions(object source, ElapsedEventArgs e)
        try
            using (SqlConnection connection = new SqlConnection(connectionString))
                connection.Open();
                string query = @"
                SELECT
                    r.session_id AS BlockedSessionID,
                    r.blocking_session_id AS BlockingSessionID,
                    r.text AS SqlText
                WHERE r.blocking_session_id <> 0;";
                using (SqlCommand command = new SqlCommand(query, connection))
                    using (SqlDataReader reader = command.ExecuteReader())
                        while (reader.Read())
                            int blockedSessionId = reader.GetInt32(0);
                            int blockingSessionId = reader.GetInt32(1);
                            string sqlText = reader.GetString(2);
                            LogBlockingSession(blockedSessionId, blockingSessionId, sqlText);
                            KillSession(blockingSessionId);
        catch (Exception ex)
            LogError(ex.Message);
    private static void KillSession(int sessionId)
        try
                connection.Open();
                string killQuery = $"KILL {sessionId};";
                using (SqlCommand killCommand = new SqlCommand(killQuery, connection))
                    killCommand.ExecuteNonQuery();
                    LogKillSession(sessionId);
            LogError($"Failed to kill session {sessionId}: {ex.Message}");
    private static void LogBlockingSession(int blockedSessionId, int blockingSessionId, string sqlText)
        string logMessage = $"[{DateTime.Now}] Blocked Session ID: {blockedSessionId}, Blocking Session ID: {blockingSessionId}, SQL Text: {sqlText}";
        File.AppendAllText("blocking_sessions.log", logMessage + Environment.NewLine);
        Console.WriteLine(logMessage);
    private static void LogKillSession(int sessionId)
        string logMessage = $"[{DateTime.Now}] Killed Session ID: {sessionId}";
        File.AppendAllText("killed_sessions.log", logMessage + Environment.NewLine);
    private static void LogError(string message)
        string logMessage = $"[{DateTime.Now}] Error: {message}";
        File.AppendAllText("errors.log", logMessage + Environment.NewLine);
说明
  1. 连接字符串:替换 your_connection_string_here 为实际的数据库连接字符串。
  2. 定时器:使用 System.Timers.Timer 类设置每10秒执行一次检查。
  3. 检查阻塞会话:在 CheckForBlockingSessions 方法中,查询阻塞会话和根源会话的信息。
  4. 终止会话:在 KillSession 方法中,执行 KILL 命令来终止阻塞会话。
  5. 日志记录:日志记录包括阻塞会话的详细信息和终止会话的操作,以及错误信息。
注意事项
  • 运行此程序需要确保有足够的权限来访问数据库和执行 KILL 命令。
  • 请仔细测试程序以确保其符合预期行为,尤其是在生产环境中。
  • 日志文件的路径和权限需要根据实际情况进行配置。
转自https://www.cnblogs.com/tianqing/p/18217020 作者:Eric Zhou
该文章在 2024/5/28 10:28:58 编辑过
