C# 操作SQL Server 公共库
2023年8月22日 15:20 本文热度 4259
基本够用,存一下,以后找起来方便
public abstract class DB
        //数据库连接字符串(config来配置)
        protected static string connectionString = ConfigurationManager.AppSettings["connectionString"];
        public DB()
        #region 公用方法
        public static int GetMaxID(string FieldName, string TableName)
            string strsql = "select max(" + FieldName + ")+1 from " + TableName;
            object obj = GetSingle(strsql);
            if (obj == null)
                return 1;
            else
                return int.Parse(obj.ToString());
        public static bool Exists(string strSql, params SqlParameter[] cmdParms)
            object obj = GetSingle(strSql, cmdParms);
            int cmdresult;
            if ((Object.Equals(obj, null)) || (Object.Equals(obj, System.DBNull.Value)))
                cmdresult = 0;
            else
                cmdresult = int.Parse(obj.ToString());
            if (cmdresult == 0)
                return false;
            else
                return true;
        #endregion
        #region  执行简单SQL语句
        /// <summary>
        /// 执行SQL语句,返回影响的记录数
        /// </summary>
        /// <param name="SQLString">SQL语句</param>
        /// <returns>影响的记录数</returns>
        public static int executeSql(string SQLString)
            using (SqlConnection connection = new SqlConnection(connectionString))
                using (SqlCommand cmd = new SqlCommand(SQLString, connection))
                    try
                        connection.Open();
                        int rows = cmd.executeNonQuery();
                        return rows;
                    catch (System.Data.SqlClient.SqlException E)
                        connection.Close();
                        Log.Error(E.Message + SQLString);
                        return 0;
        /// <summary>
        /// 执行多条SQL语句,实现数据库事务。
        /// </summary>
        /// <param name="SQLStringList">多条SQL语句</param>
        public static void executeSqlTran(ArrayList SQLStringList)
            using (SqlConnection conn = new SqlConnection(connectionString))
                conn.Open();
                SqlCommand cmd = new SqlCommand();
                cmd.Connection = conn;
                SqlTransaction tx = conn.BeginTransaction();
                cmd.Transaction = tx;
                try
                    for (int n = 0; n < SQLStringList.Count; n++)
                        string strsql = SQLStringList[n].ToString();
                        if (strsql.Trim().Length > 1)
                            cmd.CommandText = strsql;
                    tx.Commit();
                    tx.Rollback();
                    throw new Exception(E.Message);
        /// <summary>
        /// 执行带一个存储过程参数的的SQL语句。
        /// </summary>
        /// <param name="content">参数内容,比如一个字段是格式复杂的文章,有特殊符号,可以通过这个方式添加</param>
        public static int executeSql(string SQLString, string content)
                SqlCommand cmd = new SqlCommand(SQLString, connection);
                System.Data.SqlClient.SqlParameter myParameter = new System.Data.SqlClient.SqlParameter("@content", SqlDbType.NText);
                myParameter.Value = content;
                cmd.Parameters.Add(myParameter);
                try
                    connection.Open();
                    return rows;
                    return 0;
                finally
                    cmd.Dispose();
                    connection.Close();
        /// <summary>
        /// 向数据库里插入图像格式的字段(和上面情况类似的另一种实例)
        /// </summary>
        /// <param name="strSQL">SQL语句</param>
        /// <param name="fs">图像字节,数据库的字段类型为image的情况</param>
        public static int executeSqlinsertImg(string strSQL, byte[] fs)
                SqlCommand cmd = new SqlCommand(strSQL, connection);
                System.Data.SqlClient.SqlParameter myParameter = new System.Data.SqlClient.SqlParameter("@fs", SqlDbType.Image);
                myParameter.Value = fs;
                try
                    connection.Open();
                    return rows;
                    Log.Error(E.Message + strSQL);
                    return 0;
                finally
                    cmd.Dispose();
                    connection.Close();
        /// <summary>
        /// 执行一条计算查询结果语句,返回查询结果(object)。
        /// </summary>
        /// <param name="SQLString">计算查询结果语句</param>
        /// <returns>查询结果(object</returns>
        public static object GetSingle(string SQLString)
                    try
                        connection.Open();
                        object obj = cmd.executeScalar();
                            return null;
                        else
                            return obj;
                    catch (System.Data.SqlClient.SqlException e)
                        connection.Close();
                        Log.Error(e.Message + SQLString);
                        return null;
        /// <summary>
        /// 执行查询语句,返回SqlDataReader
        /// </summary>
        /// <param name="strSQL">查询语句</param>
        /// <returns>SqlDataReader</returns>
        public static SqlDataReader executeReader(string strSQL)
            SqlConnection connection = new SqlConnection(connectionString);
            try
                connection.Open();
                SqlDataReader myReader = cmd.executeReader();
                return myReader;
                throw new Exception(e.Message);
        /// <summary>
        /// 执行查询语句,返回DataSet
        /// </summary>
        /// <param name="SQLString">查询语句</param>
        /// <returns>DataSet</returns>
        public static DataSet Query(string SQLString)
                DataSet ds = new DataSet();
                try
                    connection.Open();
                    SqlDataAdapter command = new SqlDataAdapter(SQLString, connection);
                    command.Fill(ds, "ds");
                catch (System.Data.SqlClient.SqlException ex)
                    Log.Error(ex.Message + SQLString);
                    return null;
                return ds;
        #endregion
        #region 执行带参数的SQL语句
        /// <summary>
        /// </summary>
        public static int executeSql(string SQLString, params SqlParameter[] cmdParms)
                using (SqlCommand cmd = new SqlCommand())
                    try
                        PrepareCommand(cmd, connection, null, SQLString, cmdParms);
                        cmd.Parameters.Clear();
                        return rows;
        /// <summary>
        /// </summary>
        /// <param name="SQLStringList">SQL语句的哈希表(keysql语句,value是该语句的SqlParameter[]</param>
        public static void executeSqlTran(Hashtable SQLStringList)
                conn.Open();
                using (SqlTransaction trans = conn.BeginTransaction())
                    try
                        //循环
                        foreach (DictionaryEntry myDE in SQLStringList)
                            string cmdText = myDE.Key.ToString();
                            SqlParameter[] cmdParms = (SqlParameter[])myDE.Value;
                            PrepareCommand(cmd, conn, trans, cmdText, cmdParms);
                            int val = cmd.executeNonQuery();
                            trans.Commit();
                    catch
                        trans.Rollback();
                        throw;
        /// <summary>
        /// </summary>
        public static object GetSingle(string SQLString, params SqlParameter[] cmdParms)
                    try
                            return null;
                        else
                            return obj;
        /// <summary>
        /// </summary>
        public static SqlDataReader executeReader(string SQLString, params SqlParameter[] cmdParms)
            try
                return myReader;
        /// <summary>
        /// </summary>
        public static DataSet Query(string SQLString, params SqlParameter[] cmdParms)
                using (SqlDataAdapter da = new SqlDataAdapter(cmd))
                    try
                        da.Fill(ds, "ds");
                        throw new Exception(ex.Message);
                    return ds;
        private static void PrepareCommand(SqlCommand cmd, SqlConnection conn, SqlTransaction trans, string cmdText, SqlParameter[] cmdParms)
            if (conn.State != ConnectionState.Open)
                conn.Open();
            cmd.CommandText = cmdText;
            if (trans != null)
                cmd.Transaction = trans;
            cmd.CommandType = CommandType.Text;//cmdType;
            if (cmdParms != null)
                foreach (SqlParameter parm in cmdParms)
                    cmd.Parameters.Add(parm);
        #endregion
        #region 存储过程操作
        /// <summary>
        /// 执行存储过程
        /// </summary>
        /// <param name="storedProcName">存储过程名</param>
        /// <param name="parameters">存储过程参数</param>
        public static SqlDataReader RunProcedure(string storedProcName, IDataParameter[] parameters)
            SqlDataReader returnReader;
            connection.Open();
            SqlCommand command = BuildQueryCommand(connection, storedProcName, parameters);
            command.CommandType = CommandType.StoredProcedure;
            returnReader = command.executeReader();
            return returnReader;
        /// <summary>
        /// 执行存储过程
        /// </summary>
        /// <param name="tableName">DataSet结果中的表名</param>
        public static DataSet RunProcedure(string storedProcName, IDataParameter[] parameters, string tableName)
                DataSet dataSet = new DataSet();
                connection.Open();
                SqlDataAdapter sqlDA = new SqlDataAdapter();
                sqlDA.selectCommand = BuildQueryCommand(connection, storedProcName, parameters);
                sqlDA.Fill(dataSet, tableName);
                connection.Close();
                return dataSet;
        /// <summary>
        /// 构建 SqlCommand 对象(用来返回一个结果集,而不是一个整数值)
        /// </summary>
        /// <param name="connection">数据库连接</param>
        /// <returns>SqlCommand</returns>
        private static SqlCommand BuildQueryCommand(SqlConnection connection, string storedProcName, IDataParameter[] parameters)
            SqlCommand command = new SqlCommand(storedProcName, connection);
            foreach (SqlParameter parameter in parameters)
                command.Parameters.Add(parameter);
            return command;
        /// <summary>
        /// 执行存储过程,返回影响的行数
        /// </summary>
        /// <param name="rowsAffected">影响的行数</param>
        /// <returns></returns>
        public static int RunProcedure(string storedProcName, IDataParameter[] parameters, out int rowsAffected)
                int result;
                connection.Open();
                SqlCommand command = BuildIntCommand(connection, storedProcName, parameters);
                rowsAffected = command.executeNonQuery();
                result = (int)command.Parameters["ReturnValue"].Value;
                //Connection.Close();
                return result;
        /// <summary>
        /// 创建 SqlCommand 对象实例(用来返回一个整数值)
        /// </summary>
        /// <returns>SqlCommand 对象实例</returns>
        private static SqlCommand BuildIntCommand(SqlConnection connection, string storedProcName, IDataParameter[] parameters)
            command.Parameters.Add(new SqlParameter("ReturnValue",
             SqlDbType.Int, 4, ParameterDirection.ReturnValue,
             false, 0, 0, string.Empty, DataRowVersion.Default, null));
            return command;
        #endregion
该文章在 2023/8/22 15:20:24 编辑过
