C#另存为文件时选择文件、选择路径、保存文件名称路径(支持手工输入文件名称)
2022年8月9日 1:3 本文热度 5961
    class FilePathHelper
        /// <summary>
        /// 选择保存文件的名称以及路径  取消返回 空"";
        /// </summary>
        /// <param name="fileName"></param>
        /// <param name="filter"></param>
        /// <param name="title"></param>
        /// <returns></returns>
        public static string SaveFilePathName(string fileName=nullstring filter=nullstring title=null)
            string path = "";
            System.Windows.Forms.SaveFileDialog fbd = new System.Windows.Forms.SaveFileDialog();
            if (!string.IsNullOrEmpty(fileName))
                fbd.FileName = fileName;
            if (!string.IsNullOrEmpty(filter))
                fbd.Filter = filter;// "Excel|*.xls;*.xlsx;";
            if (!string.IsNullOrEmpty(title))
                fbd.Title = title;// "保存为";
            if (fbd.ShowDialog() == System.Windows.Forms.DialogResult.OK)
                path = fbd.FileName;
            return path;
        /// <summary>
        /// 选择一个文件
        /// </summary>
        /// <param name="filter">如果需要筛选txt文件("Files (*.txt)|*.txt")</param>
        private static string selectFile(string filter=null)
            string path = string.Empty;
            var openFileDialog = new Microsoft.Win32.OpenFileDialog()
                Filter = "Files (*.*)|*.*"//如果需要筛选txt文件("Files (*.txt)|*.txt")
            if (filter!=null)
                openFileDialog.Filter = filter;
            var result = openFileDialog.ShowDialog();
            if (result == true)
                path = openFileDialog.FileName;
            return path;
        /// <summary>
        /// 选择一个路径
        /// </summary>
        public static string selectPath()
            System.Windows.Forms.FolderBrowserDialog fbd = new System.Windows.Forms.FolderBrowserDialog();
                path = fbd.selectedPath;
            return path;
该文章在 2022/8/9 1:03:37 编辑过
