[点晴永久免费OA]C#根据ip获取城市地址
2022年5月31日 11:4 本文热度 5826
用的API是百度、新浪、淘宝:
1、首先是一个检测获取的值是不是中文的方法,因为有的ip只能识别出来某省,而城市名称则为空返回的json里会出现null或undefined。
1 public static bool HasChinese(string str)
2     {
3         return Regex.IsMatch(str, @"[u4e00-u9fa5]");
4     }
百度的API
/// <summary>
    /// 百度api
    /// </summary>
    /// <returns></returns>
    public static string GetBaiduIp(string ip)
        try
            string cs = "";
            string url = "http://api.map.baidu.com/location/ip?ak=GlfVlFKSc6Y7aSr73IHM3lQI&ip=" + ip;
            WebClient client = new WebClient();
            var buffer = client.DownloadData(url);
            string jsonText = Encoding.UTF8.GetString(buffer);
            JObject jo = JObject.Parse(jsonText);
            var txt = jo["content"]["address_detail"]["city"];
            JToken st = txt;
            string str = st.ToString();
            if (str == "")
                cs = GetCS(ip);
                return cs;
            int s = str.IndexOf('');
            string css = str.Substring(0, s);
            bool bl = HasChinese(css);
            if (bl)
                cs = css;
            else
                cs = GetCS(ip);
            return cs;
        catch
            return GetIPCitys(ip);
新浪API(这个是直接获取网页源代码,然后抓取)
 1  /// <summary>
 2     /// 新浪api
 3     /// </summary>
 4     /// <param name="ip"></param>
 5     /// <returns></returns>
 6 public static string GetCS(string ip)
 7     {
 8         try {
 9         string url = "http://int.dpool.sina.com.cn/iplookup/iplookup.php?ip=" + ip;
10         WebClient MyWebClient = new WebClient();
11         MyWebClient.Credentials = CredentialCache.DefaultCredentials;//获取或设置用于向Internet资源的请求进行身份验证的网络凭据
12         Byte[] pageData = MyWebClient.DownloadData(url); //从指定网站下载数据
13         string stt = Encoding.GetEncoding("GBK").GetString(pageData).Trim();
14         return stt.Substring(stt.Length - 2, 2);
15         }
16         catch
17         {
18             return "未知";
19         }
20
21     }
淘宝API
 1 /// <summary>
 2     /// 淘宝api
 3     /// </summary>
 4     /// <param name="strIP"></param>
 6     public static string GetIPCitys(string strIP)
 7     {
 8         try
 9         {
10             string Url = "http://ip.taobao.com/service/getIpInfo.php?ip=" + strIP + "";
11
12             System.Net.WebRequest wReq = System.Net.WebRequest.create(Url);
13             wReq.Timeout = 2000;
14             System.Net.WebResponse wResp = wReq.GetResponse();
15             System.IO.Stream respStream = wResp.GetResponseStream();
16             using (System.IO.StreamReader reader = new System.IO.StreamReader(respStream))
17             {
18                 string jsonText = reader.ReadToEnd();
19                 JObject ja = (JObject)JsonConvert.DeserializeObject(jsonText);
20                 if (ja["code"].ToString() == "0")
21                 {
22                     string c = ja["data"]["city"].ToString();
23                     int ci = c.IndexOf('');
24                     if (ci != -1)
25                     {
26                         c = c.Remove(ci, 1);
27                     }
28                     return c;
29                 }
30                 else
31                 {
32                     return "未知";
33                 }
34             }
35         }
36         catch (Exception)
37         {
38             return ("未知");
39         }
40     }
该文章在 2022/5/31 11:04:36 编辑过
全部评论1
2022年5月31日 11:15
ip-api.com接口(解析 json需要引入Newtonsoft.Json.dll ):
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
/// <summary>
    /// 根据IP 获取物理地址
    /// </summary>
    /// <param name="ip">Ip地址</param>
    public static string GetIpAddress(string ip)
      string url = "http://ip-api.com/json/"+ip+"?lang=zh-CN";
      string result = "";
      WebRequest wrt = null;
      WebResponse wrp = null;
      try
        wrt = WebRequest.create(url);
        wrt.Credentials = CredentialCache.DefaultCredentials;
        wrp = wrt.GetResponse();
        StreamReader sr = new StreamReader(wrp.GetResponseStream(), Encoding.UTF8);
        //获取到的是Json数据
        string html = sr.ReadToEnd();
        //Newtonsoft.Json读取数据
        JObject obj = JsonConvert.DeserializeObject<JObject>(html);
        string city = obj["city"].ToString();
        string province = obj["regionName"].ToString();
        result = city.Equals(province) ? city : (province + city);
      catch (Exception)
      finally
        if (wrp != null)
          wrp.Close();
        if (wrt != null)
          wrt.Abort();
      return result;
126.net接口:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
/// <summary>
    /// 根据IP 获取物理地址
    /// </summary>
    public static string GetstringIpAddress(string ip)
      string url = "http://ip.ws.126.net/ipquery?ip="+ip;
      string result="";
      try
        StreamReader sr = new StreamReader(wrp.GetResponseStream(), Encoding.Default);
        //获取到的数据格式:var lo="江苏省", lc="镇江市"; var localAddress={city:"镇江市", province:"江苏省"}
        string pattern = "{city:\"(?<key1>.*?)\", province:\"(?<key2>.*?)\"}";
        Regex regex = new Regex(pattern, RegexOptions.None);
        Match match = regex.Match(html);
        string city=match.Groups["key1"].Value;
        string province=match.Groups["key2"].Value;
      catch (Exception)
      finally
        if (wrp != null)
          wrp.Close();
        if (wrt != null)
          wrt.Abort();
      return result;
