百度地图划多边形圈,并判断某个经纬度是否在某个圈中
2021年1月29日 9:59 本文热度 7554
<!DOCTYPE html>
<html>
<head>
    <meta charset="UTF-8">
    <title></title>
    <style type="text/css">
        html, body {
            width: 100%;
            height: 100%;
            margin: 0;
            padding: 0;
            overflow: hidden;
        #filter {
            float: left;
            width: 30%;
            height: 100%;
        #map {
            width: 70%;
            height: 100%;
        #dealers_list {
            margin: 10px; overflow-y: scroll; height: 500px
        #dealers_list .item{
            cursor: pointer;
            margin-bottom: 5px;
    </style>
</head>
<body>
<div id="filter">
    <div style="margin: 10px;">
        <span>选择区域</span>
        <span><select id="area"><option value="">全部区域</option><option value="1">南区</option><option value="2">北区</option></select></span>
    </div>
        <span>选择城市</span>
        <span><select id="city"></select></span>
    </div>
        <span>验证是否在区域中</span><br/>
        <span>
            经度:<input type="text" name="longitude" id="longitude"><br/>
            维度:<input type="text" name="latitude" id="latitude"><br/>
            <input type="button" btn="search" value="查询">
        </span>
    </div>
    <div id="dealers_list">
    </div>
</div>
<div id="map"></div>
<canvas id="canvas"></canvas>
<script type="text/javascript" src="http://apps.bdimg.com/libs/jquery/2.1.1/jquery.min.js"></script>
<script type="text/javascript" src="http://api.map.baidu.com/api?v=2.0&ak=1XjLLEhZhQNUzd93EjU5nOGQ"></script>
<script type="text/javascript" src="http://api.map.baidu.com/library/DrawingManager/1.4/src/DrawingManager_min.js"></script>
<script type="text/javascript" src="/js/mapv.js"></script>
<link rel="stylesheet" href="http://api.map.baidu.com/library/DrawingManager/1.4/src/DrawingManager_min.css"/>
<script type="text/javascript">
    $(function(){
        //加载地图
        window._loadMap = function(cityid,dealerid){
            $.get("/test/map",{cityid:cityid,dealerid:dealerid},function(res){
                $("body").append(res);
            },"html");
        //加载区域城市
        window._loadCity = function(big_areaid){
            $.get("/test/getcitys",{big_areaid:big_areaid},function(res){
                if(res&&res.code==1){
                    $("#dealers_list").html("");
                    data = res.data;
                    str = "<option value=''''>请选择</option>";
                    for (i = 0; i < data.length; i++) {
                       str += "<option value=''"+data[i].cityid+"''>"+data[i].cityname+"</option>";
                    $("#city").html(str);
                }else{
                    alert(res.msg);
             },"json");
        //加载城市经销商
        window._loadDealer = function(cityid){
            $.get("/test/getdealers",{cityid:cityid},function(res){
                    data = res.data;
                    str = "";
                       str += "<div class=''item'' data-dealerid=''"+data[i].dealerid+"''>"+data[i].dealername+"</div>";
                    $("#dealers_list").html(str);
                }else{
                    alert(res.msg);
             },"json");
        //大区选择
        $("#area").change(function(){
             big_areaid = $(this).val();
             if(big_areaid==""){
                $("#city").html("");
                return false;
             _loadMap(0,0);
             _loadCity(big_areaid);
        window.dealerid = 0;
        window.cityid = 0;
        //城市选择
        $("#city").change(function(){
             cityid = $(this).val();
             if(cityid==""){
                alert("请选择城市");
                return false;
             _loadDealer(cityid);
             _loadMap(cityid,0);
        //经销商点击
        $("#dealers_list").delegate(''.item'', ''click'', function(event) {
            dealerid = $(this).attr("data-dealerid");
            _loadMap(cityid,dealerid);
        //是否当前位置是否在区域内
        $(''[btn="search"]'').click(function(){
            longitude = $("#longitude").val();
            latitude = $("#latitude").val();
            $.post("/test/search",{dealerid:dealerid,longitude:longitude,latitude:latitude},function(res){
                    alert(res.msg);
                }else{
                    alert(res.msg);
            },"json");
        //初始化地图
        _loadMap(0,0);
</script>
</body>
</html>
    // 百度地图API功能
    var map = new BMap.Map("map", {
        enableMapClick: true
    });    // 创建Map实例
    @if($dealer)
        //点击单一商户
        point = new BMap.Point({{$dealer[''longitude'']}}, {{$dealer[''latitude'']}});
        map.centerAndZoom(point, 13);  // 初始化地图,设置中心点坐标和地图级别
    @elseif($city)
        //选择某一个城市
        map.centerAndZoom("{{$city[''cityname'']}}",13);
    @else
        //默认显示城市
        map.centerAndZoom("北京",13);
    @endif
    map.enableScrollWheelZoom(true); // 开启鼠标滚轮缩放
    map.addControl(new BMap.NavigationControl());
    // 编写自定义函数,创建商家标注
    function addMarker(point,dealername,show_delete){
      var marker = new BMap.Marker(point);
      map.addOverlay(marker);
      var label = new BMap.Label(dealername,{offset:new BMap.Size(20,-10)});
      marker.setLabel(label);
      if(show_delete)
        var delete_label = new BMap.Label("<a href=''javascript:;''>点击图标删除区域</a>",{offset:new BMap.Size(-38,26)});
        marker.setLabel(delete_label);
        marker.addEventListener("click",function(){
            $.post("/test/removesign",{dealerid:dealerid},function(res){
                }else{
                    alert(res.msg);
            },"json");
    //添加商户到地图
    var _loadDealerToMap = function(){
        @if($dealer)
            var point = new BMap.Point({{$dealer[''longitude'']}}, {{$dealer[''latitude'']}});
            addMarker(point,"{{$dealer[''dealername'']}}",{{$dealer[''points'']?1:0}});
        @elseif($dealers)
            @foreach(dealers asv)
                @if($v[''longitude''] && $v[''latitude''])
                var point = new BMap.Point({{$v[''longitude'']}}, {{$v[''latitude'']}});
                addMarker(point,"{{$v[''dealername'']}}",false);
                @endif
            @endforeach
        @endif
    //setTimeout(_loadDealerToMap(),1000);
    _loadDealerToMap();
    //使用工具划区域后执行事件
    var overlaycomplete = function (e) {
        if(drawingManager.getDrawingMode() != "polygon"){
            alert("请选用多边形画图工具!");
            return false;
        if(!dealerid){
            alert("请先选择一个经销商!");
            return false;
        points = e.overlay.getPath();
        $.post("/test/signdealer",{dealerid:dealerid,points:points},function(res){
                //重新刷新地图
            }else{
                alert(res.msg);
        },"json");
        //debugger;
    var styleOptions = {
        strokeColor: "red",    //边线颜色。
        fillColor: "red",      //填充颜色。当参数为空时,圆形将没有填充效果。
        strokeWeight: 3,       //边线的宽度,以像素为单位。
        strokeOpacity: 0.8,       //边线透明度,取值范围0 - 1。
        fillOpacity: 0.6,      //填充的透明度,取值范围0 - 1。
        strokeStyle: ''solid'' //边线的样式,solid或dashed。
    //实例化鼠标绘制工具
    var drawingManager = new BMapLib.DrawingManager(map, {
        isOpen: false, //是否开启绘制模式
        drawingType: BMAP_DRAWING_POLYGON,
        enableDrawingTool: true, //是否显示工具栏
        enableCalculate: false,
        drawingToolOptions: {
            anchor: BMAP_ANCHOR_TOP_RIGHT, //位置
            offset: new BMap.Size(5, 10), //偏离值
            drawingModes : [
                BMAP_DRAWING_POLYGON //多边形
        polygonOptions: styleOptions, //多边形的样式
    //drawingManager.setDrawingMode(BMAP_DRAWING_POLYGON);
    //添加鼠标绘制工具监听事件,用于获取绘制结果
    drawingManager.addEventListener(''overlaycomplete'', overlaycomplete);
    map.setMapStyle({
        styleJson: [
                "featureType": "all",
                "elementType": "all",
                "stylers": {
                    "lightness": 61,
                    "saturation": -100
    @if($dealer)
    $.get(''/test/getdealerare'',{dealerid:{{$dealer[''dealerid'']}}}, function (data) {
        if(data)
            var dataSet = new mapv.DataSet(data);
            var options = {
                fillStyle: ''rgba(255, 80, 53, 0.8)'',
                strokeStyle: ''rgba(250, 255, 53, 0.8)'',
                lineWidth: 2,
                draw: ''simple'',
                zIndex: 1,
                size: 5, // 大小值
            var mapvLayer = new mapv.baiduMapLayer(map, dataSet, options);
    @endif
</script>
     * 判断是否在区域内部
     * @param  [array]  $p      需要查询的经纬度
     * @param  [array]  $points 查询的圈的经纬度集合
     * @return boolean
    private function _isInside(p,points)
         count = count(points);
         if($count < 3)
            return false;
         $result = false;
         for(i = 0,j = count - 1;i < count;i++)
            p1 =points[$i];
            p2 =points[$j];
            if(p1[''lat''] <p[''lat''] && p2[''lat''] >=p[''lat''] || p2[''lat''] <p[''lat''] && p1[''lat''] >=p[''lat'']){
               if(p1[''lng''] + (p[''lat''] - p1[''lat'']) / (p2[''lat''] - p1[''lat'']) * (p2[''lng''] - p1[''lng'']) <p[''lng'']){
                  result = !result;
            j =i;
         return $result;
该文章在 2021/1/29 9:59:07 编辑过
